Hi to all from italy... sorry form my poor english, but my deutsch ist sclechste...
by the way...
i would like to know if there's a possibility to fit a bigger throttle body "plug & play" for polo afh.... what do u think?
i'll just translate for the german users:
Er möchte wissen ob es eine größere Drosselklappe für den AFH Motor gibt, die plug&play passt.
thanks... i can read germany but i cannot write it...
some guys say that the throttle body from a golf 4 2.0 fits.
is the throttle body of the golf 4 2.0 operated by cable?
there' s advantages from a bigger throttle body on polo afh? any news around here of someone do the mods?
Somebody took a wider throttle valve on another motor, read it a few days ago but cant remember what model it was (an edged model , 2f or so i think).
All in all he measured that it wasnt really worth the effort/money.
What do you expect and what are your future plans for your setup?
Golf 4 2.0 Throttle Body has the same Size ![]()
I think theres no bigger one which will fit plug&play.
thanks... to all...
i'm going to searcing into a car cruscher.... maybe i find something...
with my motorbike i go up from standard 2x38 carbs to 2 x 40 flat carbs... and difference are .... i think 10-15%.... impressive...
the destination of my tuning is...
4-2-1 raceland mainfol
dekat
stright middel exhaust
sport end exhaust
remap on dyno
thats all...
Hat die Drosselklappe vom VR6 auch nur eine 56mm Stauscheibe verbaut ?
dekat
ich werde morgen mal VR6 messen, haben da noch 2 mit bowdenzug-gas liegen.
ich dachte aber an ne 60er drosselklappe. die wandstärke beträgt ja auch nicht nur 1mm sondern wesentlich mehr... 3-5 oder so.
What are your local laws according to emission limit values?
But still the question - is it enough bang for the buck?
but i live in a small village without many trouble for this
Größere DK gibt's genug, ABF z.b. die werden aber nicht plug&play passen..
Die größere DK alleine wird eh nicht wirklich was bringen.
beim mopet bringt es aber nur was wenn die vergaserbedüsung angepasst wird. also müsstest du den spritdruck anpassen.
